Experience Builder Edit Widget Not Functioning Correctly
8162
21
04-27-2022 03:34 PM
KaraUtter
After adding my editable layers, they aren't showing up properly in the Edit widget. None of them are present but there is a strange one showing up, please see image below.
KaraUtter
Now I see that when I turn on my layers, they do appear in the new feature portion of the edit widget, however that weird "jimu-draw-measurements-layer-widget......." is from the draw tool. Why does that have to be there and if it has to be there, why can't I rename it to something that makes sense?
KaraUtter
None of this will make sense to anyone and I am forced to have it up there because I Have both the edit and draw widgets connected to the map. It makes no sense but I can't see how to get rid of it?
TonghuiMing
Hi @KaraUtter - for the extra layer from the Draw widget, we will take a look and fix it in the next upcoming release. Sorry for the inconvenience. (Further details in https://community.esri.com/t5/arcgis-experience-builder-questions/draw-layer-displays-in-edit-widget... )
KaraUtter
Thanks, Tonghui. Do you know the date of the new release?
TonghuiMing
The Q2 release should happen sometime around late June or early July according to previous practice.
KaraUtter
Bummer! The department I am building this app for is going to be confused by this. They aren't as savvy with anything on a computer so this is just going to get in the way for them, unfortunately.
TonghuiMing
This issue should be resolved with AGOL 10.2 release today.
KaraUtter
Well, the issue above was resolve and replaced by a new issue. As soon as I add my first editable layer that I want connected to the edit widget, it adds a bunch of other layers that are not editable and says, "highlight" next to them???
TianWen
It looks like a data-specific problem. I think it would be helpful if you can provide sample data. 🙂
