Experience Builder Edit Widget Functionality Inconsistent Between Pages
933
03-24-2025 09:07 AM
CaraSteinberg
Having a weird issue with my Edit Widget in Experience Builder. The widget is very inconsistently loading the "Update and Delete" buttons at the bottom of the widget pane. I want to be able to click a feature in my map and edit attributes only, but the behavior is unexpected. It seems to happen kind of consistently when navigating between pages, but sometimes it doesn't work at all (regardless of how I am navigating the pages). I have looked around online and I can't seem to find the bug logged or a solution anywhere. All of my layer and map settings enable editing. I have tried different browsers, different accounts, refreshing, and I can't seem to figure it out. Any suggestions are welcomed, thanks!
Laura
by MVP Regular Contributor
I believe if you are the admin you will always see the delete button.
CaraSteinberg
That makes sense, but the entire "Update and Delete" button area disappears without apparent cause.
TianWen
Thanks for the post! It would be helpful if a sample app could be provided. Thanks!
