Experience Builder Doesn't Support Audio in a Feature Layer
5991
16
05-04-2020 12:36 PM
Amanda__Huber
MVP Regular Contributor
Hello ArcGIS Experience Builder‌ Team,
We currently have a feature layer that has an audio file- the audio plays perfectly in web maps, the item details table, and other apps- but when it’s added to EB the audio file breaks/doesn’t play. This seems like a equivalency issue and we would really like to leverage Experience Builder for this upgraded GIS application but cannot due to this bug/limitation. I have opened a support case about this as well (Esri Case #02549075) but wanted to see if anyone from the EB team could take a look at this issue.
Thanks!
Experience builder- doesn’t work-
Data table on items details page- works-
Webmap popup- works:
Thanks so much,
Amanda Huber
Jianxia
This issue will be fixed in the upcoming update.Thanks for the following up Amanda.
Amanda__Huber
Hi Jianxia Song‌,
Great to hear! Will this be in the June 30th ArcGIS Online update then?
Jianxia
Yes, the fix will be in the June 30th update.
Amanda__Huber
Great to hear, we can't wait to see it. Thanks for all your communication!
Best,
Amanda
DanielleMahon
Hi there,
I am trying to add an .mp3 file as a feature layer for the "embed" widget in Experience Builder to pull. Is this possible? I'd like to know if there is a work around, please. Thanks!
LayerItOn
Hi @Amanda__Huber, how were you able to get the audio player in your webmap? Is it embedded using the pop-up editor?
I have a feature layer with audio attachments. I would love those to play with an audio player right in the popup instead of opening on a separate web browser page when clicked on.
Do you have sample code? Thank you in advanced!
LayerItOn
Update: html embed from google drive is no longer supported by google.
Original Comment:
Got it to work within a text column in ArcGIS pro:
<audio class="player" controls preload="none">
<source src="https://drive.google.com/uc?export=open&id=17zlUkdLsKMNOaqVJJwn0SPK8hd_RHgox" type="audio/mp3">
</audio>
