Experience Builder 1.13.0 , Node Version 16.16.0 - Unable to Download Experience Zipfile
1575
01-28-2024 11:29 PM
Labels (2)
ARVINDKUMAR
Can anyone help me? I am using Experience Builder 1.13.0 and Node Version 16.16.0. I am unable to download the Template Zip file that I created on my local server. When I click on the download option, it shows 'No Item'.
JeffreyThompson2
MVP Frequent Contributor
Possible solution if the EXB download fails - Esri Community
We have been trying to solve this issue as a community for some time now and we don't really know what is causing it or how to reliably fix it. The problem appears to have multiple causes. The easiest possible solution is to run your Command Prompt in Administrator mode. Another possible issue is that the download is being blocked by your antivirus or firewall, so try disabling those. See the attached thread for further discussion and several more complicated solutions.
GIS Developer
City of Arlington, Texas
Layelmam_Mohammed
Hello I have the same problem. I have EXD version 1.13 and I have tested several versions of Node 16 18 20 but I cannot download the Zipfile. I hope that an ESRI technical manager can answer me, I cannot contact ESRI support, it is urgent.
