ExpB popup not functional on imagery layer
1825
10-09-2024 06:19 AM
AngieCausey
We are leveraging the AGOL Experience Builder app in order to leverage the Elevation Profile widget available in that tool.  Our Web Map contains a lidar dataset published as an imagery layer.  The popups are enabled on the web map and work properly to show the pixel values with in the web map viewer, however, the popups do not work in the experience builder application themselves.  Below is the message that appears in the developer console when clicking on the map...
JimuLayerView widget_6-dataSource_2-1926cd0ce03-layer-5 create layer data source failed: g: data source id: dataSource_2-1926cd0ce03-layer-5, Failed to create the data source.
It is important to note that the imagery layer displays properly when the experience loads and is in the Web Mercator projection.  It is the only layer in the web map.
Ke_Xu
by Esri Regular Contributor
Hi @AngieCausey ,
Please check the imagery service, if there are any fields in Fields. We found a bug earlier that was related to this.
If there are fields in the service, could you share the imagery service to help us continue troubleshooting, thanks.
Ke
AngieCausey
Thank you Ke_Xu for your response.  The service does not have any fields.  Here's the link: https://maps.scpgis.com/imagehost/rest/services/Imagery/stch21_lidar_WebMercator/ImageServer  I believe you should be able to access it.
Ke_Xu
Hi @AngieCausey ,
There is also no fields for a (dynamic imagery) layer.
The bug has been logged as BUG-000169365 and it will be released soon.
Ke
jackwilks
I've also noticed this exact issue appearing in ArcGIS Experience Builder Developer Edition (1.15). Will this also be investigated as part of BUG-000169365?
Ke_Xu
This bug will be fixed in ArcGIS Experience Builder Developer Edition (1.16).
