ExB Search Widget not behaving.
3122
6
01-14-2024 07:52 PM
AbdulRaufs
I am facing a strange issue here with AGOL ExB search Widget. It is not showing the suggestions when something is typed and only get message "no results found......."
But when you hit enter after typing full field value, Result Panel does not show unique values.
Layer connected to ExB is publicly shared from Portal.
Any hints to solve the issue is appreciated.
Regards,
ShengdiZhang
This appears to be a service issue. The query is not supported by the portal layer when both the Geometry Filter (Map - Extent Changes - Filter data records) and Distinction (search suggestion) are applied to the service.
This is a known support issue and you can follow issue BUG-000140112.
Regards,
Shengdi
ShengdiZhang
Hi @AbdulRaufs
Is there a sample app I can take a look at?
Shengdi
bradbrewer1
I am having a similar issue. If i want to search for 401 W Washington St and i type in the search bar 401 W Wash, no suggestions. I've tried typing the full address and still no suggested search results. When i hit search it still finds the address but I know alot of people rely on those suggested searches. I don't want to publish my maps to the public with the search function not working.
ShengdiZhang
Here is a similar post https://community.esri.com/t5/arcgis-experience-builder-questions/full-text-search-index-on-hosted-f...
We plan to include a fix in the next release.
Shengdi
AbdulRaufs
Hi @ShengdiZhang,
This is the ExB which has its layers published in AGOL, where the ExB search function working fine.Urban Tree Map_V1 - Overview (arcgis.com)
Now i am replicating this ExB and directing it to our portal layers but search function is not giving the same functionality. Urban Tree Map_V3 - Overview (arcgis.com).
Regards,
Abdul.
ShengdiZhang
Regards,
Shengdi
AbdulRaufs
Thanks for the update. Looking forward for the resolution of this bug.
Regards,
Abdul.
