ExB Search Widget & Layer Visibility
673
10-17-2024 12:00 PM
ScottR
Is there any way to have the Search Widget make a layer visible when a result is selected?
Currently upon selecting a result, the map will pan/zoom to the correct location and even show the pop-up, but if the layer is toggled off in the map layer list, the result will not be highlighted.
AnnaEssington
@ScottR  I'm running into the same issue. Have you found a work around since this post?
