ExB SDK 1.9 Search widget When Inside Widget Controller Bug?
636
11-02-2022 07:57 PM
HeesuLee
Hello everyone,
We are currently using Enterprise 10.8.1 and ExB SDK 1.9.
The ExB SDK has a default Search Widget, that we put into a Widget Controller widget in our custom ExB App, but we found a bug? that we don't know how to fix.
When nothing is searched (Pic 1) and I close the widget (with the X), the widget closes normally. (Pic 2)
1. Nothing searched1. Nothing searched2. Closes as it should2. Closes as it should
But when I search something that shows no results, or does return results (pic 3 and 5) and close the widget,
the search result still remains on the screen in the left side as shown below (pic 4 and 6)
3. Search with NO result3. Search with NO result4. Show no result found in left side4. Show no result found in left side5. Search WITH results5. Search WITH results6. Show the results in left side6. Show the results in left side
The only way to "fix" this is to delete the search area so that it is the same as pic 1 before closing the widget.
I couldn't find any other cases online so I don't know if other people have experienced this before.
I don't want the user to always delete the search area everytime they close the widget. Is there a solution to this problem that I am missing, or at least a work-around?
*I also should mention that while testing on AGOL, it didn't produce the same bug.
