ExB performance issue
1276
08-12-2024 05:00 AM
KenBouchard
Hi there,
I just built a new Experience Builder and I'm experiencing a performance issue.
It's a simple ExB with a map, a table, and an editor. When I click on a record in the table, it zooms to a point on the map and opens the edit widget to edit the data of that point. It takes 9-10 seconds to go from 1 selection to another... I have 215 features in this layer, really nothing.
Curiously, I have another ExB that works pretty similar on a layer with over 5000 points and it works flawlessly, moving from one dataset to another within a second.
Has anyone experienced something similar? Does anyone have any idea what could be causing this?
Thanks in advance!
Ken
Laura
by MVP Regular Contributor
I had slow reactions when my dedicated instance number was not high enough.
Junshan_Liu
It would help us identify the reason if you could share a sample app.
KenBouchard
Through testing, I've come to realize this is not about ExB at all.
It's the layer itself that respond very slowly.  Any edits I try to do in a new web map are taking the same amount of time (10 seconds).
If I click on the "View URL" from the ArcGIS Online overview page, it takes forever to load the page, way more than any of my other layers.
I've tried rebuilding the indexes, didn't change anything...
Ken
