ExB Filter Not Working for Short Integer
502
8
06-25-2026 10:39 AM
Teresa_Blader
Group filter with small integer field isn't working with unique selectors. It worked just fine for the past few months and then today isn't working. I cannot scroll through. I hit search, start to type, and then it just can't do the search. It just spins and spins. This worked until today I was alerted about it. No changes to the ExB were made in the meantime. This happens with both the drop down and expanded. I can use 'User Input' and it works fine to filter.
My other group filters with drop downs don't seem to have this issue, but they are string.
The field is identical between all three layers in the group filter, has the same range of values even.
I tried clearing browse cache, removing the filter, re adding it. I'm stumped. I don't see any corrupt values in the search. There are no null records or anything.
There is a range of values between 1 and 230... so when I type 2, I should get all of the ones that start with 2. But it like crashes after digit 1. It will briefly show one match and then the suggestion disappears right away.
 No search: seems this it works... but...
Scroll down, can't return all the records.
User input works fine:
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
StephanieW
Hi @Teresa_Blader the Experience Builder Update completed last night, are you still seeing the behavior today? If so can you please let me know if the service you are using is hosted in ArcGIS Online or ArcGIS Enterprise? Thank you!
Teresa_Blader
Unfortunately this is still an issue. I do see a slight improvement. Like it's maybe grabbing a few more numbers, but is still not displaying all the records when I scroll or finding a record when I search.
This is ArcGIS Online.
Teresa Blader
Olmsted County GIS
TonghuiMing
@Teresa_Blader We gave it a test and found out that it is not a new issue; it occurs on the last version as well. Do you have a sample app with the data to share with us? Thanks
Teresa_Blader
Sounds like you were able to replicate the issue? This definitely is a 'new to us' issue. We created the ExB app maybe fall 2025. Unless we were never quite triggering the issue maybe?? But we were definitely looking up all kinds and not having an issue.
This quite a complex project actually so I don't have a sample app and I also can't just share the data. I can however share a blank dataset that i created for my other esri support ticket related to survey123 reports. However I'm fairly certain you will probably look at it and not understand the data structure... or maybe you will. The group filter is attempting to filter the producer ID field in the tables Farmer Info, Farmer Forms, and Contracts. In my data there are 230 producers in the Farmer Info table with unqiue producer IDs. This filter then also has actions to impact all three tables.
actions to trigger the filtering better:
Teresa Blader
Olmsted County GIS
TonghuiMing
@Teresa_Blader Thanks for the data. Is the data an online HFL or a referenced layer published as a web service?
Teresa_Blader
It was published to AGOL as a hosted feature layer from ArcGIS Pro. Not a web service.
Teresa Blader
Olmsted County GIS
TonghuiMing
Thanks to your screenshot, I was trying to re-create the group filter. However, when I use the GBD to publish, it seems there is only one record. Thus, I'm afraid I cannot easily reproduce the search behavior with multiple values that you have, unfortunately.
Is it also happening in a single filter? We find something similar in a single unique dropdown, in v1.20, but not for a group filter, though:
I'd suggest the Esri Support so that we can get the exact case of yours to see if they are from the same root.
Tonghui
Teresa_Blader
Correct, I had to delete the data since it is private farmer information so someone would have to populate probably like 200 test records.
At this point, going through Esri support to figure this out is too much effort with all of the testing they'll ask me to do and re-explaining for something so simple. I've got like another big support ticket with a different issue for this project. So I'm just going to not use the drop down options. I have to move on.
My single filters do not do this, but those are strings and not integers. When I try it with the integer field in each of the three tables, not using group filter, I don't see any issue with pulling up the full range. I do know that the range of each table isn't identical. Table 1 is maybe 2-230, with records that get deleted in between. Table 2 is maybe 0-230. Table 3 is maybe 2-210. So I wonder if that's has something to do with it maybe.
Teresa Blader
Olmsted County GIS
