EXB Developper : ssl certificate error
1061
02-15-2023 09:31 AM
Rémy_Gourrat
i want deploy EXB developper behind Apache 24 httpd with proxy mode.
In my ssl-httpd.conf i set this instruction ;
ProxyPass		/arcgis_exb_dev http://localhost:3000
ProxyPassReverse	/arcgis_exb_dev http://localhost:3000
but in exb i think there is an automatic redirection from 3000 to 3001 port,
and if i use https://localhost:3001 autosigned cert generate an ssl error certificate,
it's not very clear for me.
Can'i desactivate the ssl redirection for exb for using an http like in my apache24 conf ?
is there another way ?
thanks for your help
Rémy
kyle_coldstream
Hi, I'm running into the same issue and wondering if you found a solution? Thanks
