ExB Dev Batch Edit tool for related records
580
03-22-2026 12:49 PM
PiotrCienin
Good morning,
Is there a batch editing widget in Experience Builder Dev Edition (v 11.6) for the Enterprise environment?
I found such a widget (unfortunately) in AGOL.
If it's not there (I can't find the answer to this question), has anyone created one for their own needs and would be willing to share?
Basically, I'm looking for a tool that would allow me to select objects on a map and then batch-update records related to each other in a table. I'd be grateful for any responses.
Best regards to everyone.
ClioClark
Hi @PiotrCienin,
If you are able to upgrade to ArcGIS Experience Builder Developer Edition 1.18, this supports batch editing for 2D data: https://developers.arcgis.com/experience-builder/guide/whats-new/#:~:text=Supports%20batch%20attribu...
Alternatively, if you are able to upgrade to 1.19, this includes further improvements to the batch editing functionality - https://developers.arcgis.com/experience-builder/guide/whats-new/#:~:text=Supports%20batch%20attribu....
All the best,
Clio
PiotrCienin
Hi @ClioClark,
Thank you very much for your reply. I'll try updating to the version you mentioned and get back to you with an answer. All the best.
Piotr
PiotrCienin
Reply from my ESRI advisor:
Therefore, this functionality is not available in the Experience Builder Dev Edition you are currently using.
When planning to deploy a higher version of Experience Builder Dev Edition, please note that Esri recommends using the ExB Dev version that is compatible with your ArcGIS Enterprise release.
For example, for Enterprise 11.3, the recommended version is ExB Dev 1.14.
Using newer versions may result in feature or widget incompatibility.
About release versions | ArcGIS Experience Builder | Esri Developer
