ESRI World Geocoder result display
990
03-27-2022 04:57 PM
LarryFox
I just built a web map using Experience Builder and am having trouble with the way in which the results of ESRI's World  Geocoder display on the map.  In my web app, when the result is found, it places a black dot on the map.  However, in Experience Builder, it does not.  The two pictures attached are of the same search but in the two different applications.  I don't see any options to change such a setting.  Has anyone else encountered this same problem?  If so, were you able to resolve it?  Thanks in advance.
