Empty Experience Builder Tables
1612
01-29-2025 11:07 AM
JillianStanford
Hi All,
I'm upgrading an ExB Dev app from 1.14 to 1.16. I can also recreate this issue in AGOL Experience Builder.
I am glad that the attribute table can now interact with the map, it is so much easier to set up and maintain.
I'm having trouble with some of the tables appearing empty. I've narrowed this down to layers that have popups configured that don't have the OOTB configuration of a field list.
For example, we have a layer that formats the display of attributes using the Text card.
In the app, the table is empty but the record count is correct.
It's possible to view the data if you use the Show/Hide Columns button but it's quirky - You have to click the "Show Selection" tab and then unselect and reselect each column you want to view. If you close the table or resize the app you have to turn on all of the fields again.
We also have a couple of layers that are configured to use the Title card but not show any fields. We get the same empty table behavior.
I see why it makes sense for the table widget to honor the visibility of the fields set in the popup but what is the work around for when you want the popups to be customized and the table to be useable?
Thanks!
Shen_Zhang
Hi @JillianStanford
Could you please share a sample map or app? I wasn't able to reproduce this bug.
Shen Zhang
UntitledMap
Hi @Shen_Zhang - My apps have also been having this issue for awhile now. My company is on Enterprise 11.5, and we use the web version of Experience Builder.
feel free to email me: [email protected]
amarcz_cc
I have also been experiencing this within Experience Builder for the past year. I found a work around which is tedious is you have a lot of tables.
When connecting the table to the data, do the following:
  1. Mode = Select Layers (Not Interact with a Map Widget)
  2. Select Layer and under the Configure Fields = Customize.
  3. Select the fields you need to show
