Embedding ArcGIS Dashboards in Experience Builder - change of URL-parameter at runtime without reloading the dashboard
2025
12-09-2024 04:04 AM
AndreasHall
I have a question related to embedding an ArcGIS Dashboards in Experience Builder. I'm using the Embed Widget and ArcGIS Dashboards URL parameters to create an interaction between a widget in Experience Builder and the dashboard. The documentation for Dashboards states that "changing a dashboard's parameters at run time does not cause it to reload in most modern browsers". This I can confirm. However, I cannot get this to work inside the embed widget. When the URL-parameter of the Embed widget changes after I select an object in another widget, the dashboard reloads.
Screenshot of the configuration of the embed widget with data connection, URL-parameter of dashboard underlined in red:
I have attached a screen recording of the behavior. First, it shows how it works in dashboards, when I manually edit the URL-parameter, then, it shows how in Experience Builder, it reloads the whole Dashboard.
(view in My Videos)
Does anyone know if it is possible to change the URL-parameter without this reloading of theentire dashboard?
andrew3092
I am getting the similar issue. When embedding a dashboard. The Dashboard reloads every 40 seconds. When deployed as a view within a section.
