Elevation Profile Widget - custom elevation layer
9332
17
02-18-2022 07:47 AM
StephenKing3
I'm trying to set up the elevation profile widget in Experience Builder and would like to use a custom elevation layer, however, when I insert the URL for the custom layer, it is not accepted - I get the error 'Enter the URL for a valid elevation layer service'.
I created the elevation layer service from ArcGIS Pro using 'share as web service' from my elevation surfaces ground layer and this has uploaded as a tiled elevation service on ArcGIS online.
Can anyone advise what else is required?
Thank you.
RandyMcGregor3
I don't see the Elevation Profile widget in ExB. I'm using Portal for ArcGIS. Is it only available for ArcGIS Online?
AlixVezina
@RandyMcGregor3  it's only available starting at Enterprise 11.0: Widgets—ArcGIS Experience Builder | Documentation
RandyMcGregor3
Thanks!
sigccil
Hey AlixVezina,
This is still the issue a year later and I have been using the document you linked too to create my own custom tile. Is this something you could add to the documentation since it might help others?
AlixVezina
@sigccil  Yes, that's a good thought. Following this original report, we've added a note in the documentation with these resources: Elevation Profile widget—ArcGIS Experience Builder | Documentation
becyr
@AlixVezina is it required to have an image service to publish out the elevation layer?
AlixVezina
Hi @becyr , please see this documentation for details > Publish hosted elevation layers—ArcGIS Online Help | Documentation
BillFox
MVP Notable Contributor
