Editor Widget Defaulting to "No Value" When Domain Item is Selected
1056
04-25-2025 07:38 AM
azainomv
Hi all,
I'm running ArcGIS Experience Builder through ArcGIS Enterprise version 11.3.0. I have created an app for my colleagues to verify field records in a feature class using the Editor widget. I have domains set up for them so they can choose from a set of pre-defined values. However, when using the app in the field, when they try to click on an option, it automatically defaults to "No Value". Is anyone else having this issue?
EmilyGeo
Hi @azainomv
No, I haven't seen that. Its possible that it could be a bug, but we would need more information in order to investigate.
When you configure the form in Map Viewer, you'll see the option to remove 'No Value' from the list of choices for that field. That could be a workaround for the time being.
If you continue to see this problem, please reach out to tech support so they can help with troubleshooting.
Best, Emily
azainomv
Hi, thank you for your response! Where can I find these properties in the Edit Widget in Experience Builder?
Edit: never mind, found it!
