Edit Widgets Not Working on Multiple Pages in Experience Builder
1798
09-05-2024 07:57 AM
aawadrsk
Hi everyone,
I’m configuring an Experience Builder application with multiple pages, and I’ve added a widget controller in the page header that includes an Edit widget. The same layer is used in all the maps across the different tabs, but when I try to configure the Edit widget, it only gives me the option to select the layers from the current map.
When I configure it for just one map, the Edit widget doesn’t work properly on the other pages, and all the features are grayed out.
Has anyone encountered this issue or found a way to configure the Edit widget to work across multiple pages? Any advice or solutions would be greatly appreciated!
Thanks!
aawadrsk
Hi Alix, any idea about the prolem above?
@AlixVezina
RoseSimancasM
Hello @aawadrsk
I understand that you are using the same layer on all the pages. I was wondering if you are also using the same map across all the pages, or if they are different maps?
You need to configure the widget by adding a "New Editable Layer", Select "Data," then click the "Add New Data" This function is located at the bottom of the panel. You can choose whether to use data from a map or from a layer, based on your preference and then click "Done."
The Science of Where
