Edit widget will not update features
2419
02-05-2025 02:23 PM
JamesBurton1
I am working on an experience builder where I want to allow creation and editing of features using the edit widget, but the edit widget is being glitchy and does not update features. I have editing enabled, I'm able to edit the hosted point feature layer in a web map form or in a sidebar table in experience builder. So, I know the editing works. But, when I try and edit using the edit widget, it just sucks. There are text fields that don't let me put a cursor in them, I can only get a cursor into those text fields if I tab down to them from a field above. And most frustrating of all, the update button just does not work.
Anyone else having similar issues?
TianWen
Thanks for the post! A sample app would be helpful for further investigation if possible.
JamesBurton1
Not really able to share publicly. I've done some testing and I've isolated it to the experience builder I'm using that causes this issue. I recreated this app it it's own experience builder and I'm able to put my cursor in all fields and create/update data. The weird part is when I embed the working application into a page on my existing experience builder, it has the same issue as before where it limits what fields I can put a cursor in and does not allow any updates.
Any idea what setting in Exp Builder would restrict updates to the data? I can't figure it out.
JeremyBrown4
I'm having a similar problem with the Update and Delete buttons randomly not showing up, even when editing the exact same record. I can reload the Experience several times and sometimes they will show up, but most of the time they are not available at all. The weird thing is, it works perfectly in Live View mode within experience builder, but not when I save and preview, or publish and launch.
AndrewWallick
We're having the exact same issue, the update and delete buttons sometimes do not show up. Usually if I refresh the app page, that causes them to appear.
OFOAdminGIS
We are also having the same issue with the update and delete buttons.  It started a few weeks ago, we think after the last AGOL update.  It works for some people and not others and changes daily! We desperately need to find a solution.  We're currently working with ESRI helpdesk but are having no luck.
