Edit Widget Title Bar
1480
7
10-09-2025 12:18 PM
doronwen
Anyone knows how do I control what goes into the title bar of the Edit widget tool?
Right now it shows as "undefined" and I do not see any option in the Experience Builder interface to change it.
I'm using Portal 11.3
Tags (1)
Laura
by MVP Regular Contributor
Portal or AGOL? This is what I see in AGOL & 11.2 portal
It looks like undefined is where edit or create features should be vs a title. I create my editing forms in map viewer using smart forms and you can set up titles, group names, etc.
doronwen
Sorry Portal 11.3
EmilyGeo
You can set the form title in Map Viewer.
doronwen
Where in Map Viewer do you see that option?
EmilyGeo
Hi @doronwen
To add a form title in Map Viewer:
select the layer,
click Configure editing > Forms,
then set the Form title in the window that opens.
doronwen
I do not see that option in my form. My org is still using Enterprise 11.3.
I'm assuming that option is available in newer versions?
Laura
I have form titles in Enterprise 11.2
