Edit Widget default values (Developer Edition 1.11)
2264
03-29-2023 10:00 PM
LeonAus
I'm wondering if someone can help me solve the puzzle of getting the default values for fields to populate in the edit widget when creating a new feature.
I have 4 fields setup in a feature service (AGS 10.9.1, data in enterprise geodatabase) with a domain and default value:
and I have added that layer to a webmap, then to ExB Dev Edition 1.11 Edit widget.
When I create a new point, it only applies the default value for one of the 4 fields:
I can't see a reason why that one is set and the others aren't.
Any ideas?
TianWen
How do you publish the services? There is a problem with ArcGIS Pro previous than 3.0. You can update your Pro to the latest and try it again.
LeonAus
A colleague has upgraded pro to 3.1 and tested this and it appears to have fixed the issue. Thanks.
ErinCovill11
Hi, this is happing to me in 3.2, any solution for this version?
