EB Search Widget
1652
07-25-2023 08:08 AM
JoseSanchez
Hello everyone,
I am EB with  AGOL
When searching for an address or location when clicking the address EB zooms to the location but does not  show exactly where it is. Also when EB zooms it disables layers, so we have to click on the X to make them visible again.
Is there a way to change that?
ShengdiZhang
Hi @JoseSanchez ,
You can set a custom zoom scale in the message action settings.
The reason is that the layer is filtered by the search. To modify this, you can disable the option "Enable filtering for layer source search".
Regards,
Shengdi
JoseSanchez
Thank you @ShengdiZhang
I used Custom Symbols to pinpoint the address location in the map.
And also I unchecked  the option "Enable filtering for layer source search", in order to keep all layers that are visible, otherwise they disappear (filtered).
Thanks
