EB Offline installation
4874
9
02-23-2024 11:07 AM
CliveSwan
Greetings
I have spent hours trying to install an offline Experience Builder. I followed the steps.
Point 5
npm configure get cache
Point 6/7
I copied the folder to user\Appdata\local
Point 8
npm install --offline
This throws hundreds of warnings.
Then crashes with ERR code ENOTCACHED
I am running an off-line installation, so why is it crashing trying to get:
http://registry.npmjs.org/react
Failed: cached mode is 'only-if-cached' but no cached response available.
I uninstall and reinstalled npm.
Opened a new cmd window. But still can't install /client
I would appreciate a solution to this!
Thanks
Clive
Tags (1)
tigerwoulds
We're running into this too on version 1.14. What version of node are you using? Using 18.x fails immediately, trying to reach http://registry.npmjs.org/react. Using 16.x runs with warnings but eventually errors trying to reach the internet. Has anyone got this working?
JanSarata
Hi @CliveSwan
I can observe the same thing installing ArcGIS Experience Builder Developer Edition 1.13 offline.
I have found out there is a BUG-000164137 reported. I believe this BUG is reported only internally so probably you cannot see it publicly. Hopefully the v1.14 will have this BUG resolved. v1.14 should come in the end of the March 2024.
Greetings,
Jan
tigerwoulds
PriyankaRai
We have tried experience builder 1.13 & 1.14 both are having same issue with client installation. It is trying to reach external website but since it is offline package it shouldn’t be doing this.
Earlier we had done installation of 1.12 version successfully but now it we are trying to do again client installation fails.
Please share if anyone has managed to do installation successfully so far.
we are using node 20.12.2.
Thanks
codethemap
You need download the react package from the machine which has internet and install those in EB machine.
JanSarata
There is a possible workaround which is not approved but it could help.
FW: 'In case it helps we ran into this problem as well and got it working by starting with a clean npm-cache directory and running just "npm install" on a computer with internet access. Then taking the npm-cache directory and using that instead of the one currently available for download,'
CS_IBM
Hi Jan,
Thanks for the message and advice.
I am doing an Offline EB installation.
I get an error message: npm ERR! code ENOENT
Do I need to uninstall Node + EB, then reinstall Node??
npm ERR! syscall open
npm ERR! path C:\Users\ci000030/package.json
npm ERR! errno -4058
npm ERR! enoent ENOENT: no such file or directory, open 'C:\Users\ci000030\package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
wadsonmakari
Hi all,
I am having the same issue described here (running ExB 1.14, Javascript API v4.29, ArcGIS Enterprise 10.9.1, Node 18) and tried the suggestion from @JanSarata . The offline install runs successfully after using the "online npm-cache" instead of the one available for download from the ESRI Experience developer website.
I have now hit another issue where I cannot create an experience. Inspecting the console window shows ExB is trying to get to "https://cdn.arcgis.com/sharing/rest/content/items/aa30dd52509a4fea939ccbfc3c3e14de/resources/styles/....
This is strange as this is an offline installation and should not be trying to access an online resource? I wonder if using the "online npm-cache" is the root cause for this? Has anyone used the suggestion from @JanSarata successfully in an offline installation? I would expect my offline installation of experience builder to try and access resources from my ArcGIS Enterprise Portal that I have specify when I launch it.
JanSarata
Hi @wadsonmakari
Have you changed the url of jsapi as is stated in the instructions at https://developers.arcgis.com/experience-builder/guide/install-guide/#offline-install ?
Another 'not-approved' approach is to take folders /client/node_modules   and  /server/node_modules  from the successfully installed online instance of Experience Builder DE and just place these folders into appropriate folders at offline environment with Experience Builder. Basically this approach completely skip the process of installation (npm install --offline). Then you can just npm start and it should work.
CS_IBM
Greetings,
I copied a new node-cache folder.
When I ran npm install --offline.
I got the npm ERR! code ENOTCACHED again??
Does ESRI have a working EB that can be uploaded + work offline??
