Dynamic Content Rounding
13606
19
01-27-2021 06:44 PM
by Anonymous User
Not applicable
I'm using a text widget in Experience Builder and added a dynamic value.  The value in one case is -0.276.  I want to convert this to a percentage which typically entails multiplying it by 100.   The result becomes -27.63384185.
Can I round this to 1 decimal place in the expression box?   The Round function (thinking Arcade and Python) doesn't work.  I'm presuming the only functions that work are the ones listed in the tool (Average, count, sum, min, max).     How does one control the appearance of numbers in a calculation?
Brian
ANesdoly
Has the rounding of dynamic text been implemented and updated yet? If so how can I use this feature?
Jianxia
@ANesdoly not yet. The March update is planned to be out this Wednesday PST.
MichaelGaiggEsri
Rounding is available in Experience Builder:
- connect your element (e.g. text) to data
- select the element, click the database icon to specify dynamic content and select "Expression" tab
- in the bottom left corner there is a gear icon that opens the "Number formatting" window, toggle it on and specify decimal places, to show thousands separator, and display unit
- select attribute and click insert button
GiulioMol
I think this method is only for customizing use, not for use on portal
Jianxia
This capability is in ArcGIS Enterprise 11.0, released in July 2022.
jerome6
I don't see the gear icon at the bottom of the Expression tab. Am I using an older version of EB?
AlderMaps
Thank you! Stumbling around in AGOL today and couldn't find it for myself 😅
WhitneyPatterson
@Jianxia - any update on being able to round dynamic content in text widgets in Experience Builder?  Or any formatting of dynamic content? (IE being able to display the value of $145,321 as $145.3K).  Our EXBs look very messy.
BRogers92
What @MichaelGaiggEsri mentioned in his post in the most up-to-date way that I found. It is a little janky at times, but works as intended.
GISAdmin39
I'd love to be able to do this with statistics. I've got a chart widget that shows the sum of a category by percent, and  it gives me percent to 3 decimal places, which overlaps other values.
