Duplicate values when using Query Widget 'is any of' operator
1546
05-07-2024 10:22 PM
EmilyMc
Hi Team,
We have an Experience Builder application that uses the Query widget. We have found that when using the 'is any of' operator in conjunction with a field in which one or more of the attribute values contains a '/' the associated values are duplicated within widget. This occurs when using either the pill selector or dropdown list input styles. In particular with the pill selector, upon selecting a value that contains a '/' a third pill containing the same value is displayed.
Is this a bug? Or are '/' values not supported in the query widget?
Thanks!
EmilyMc
We attempted to work around this behaviour by using the filter widget, but we have experienced the same behaviour. Any help would be greatly appreciated! Thanks!
TonghuiMing
Hi @EmilyMc, thanks for bringing this up, and it does look weird. Is it possible for you to share sample data that we could investigate?
EmilyMc
Hi @TonghuiMing I'll check internally! Thanks
