Draw a shape that selects features then export the shape and features
1759
02-20-2024 11:20 AM
mhbangs_EDC
Hello,
I am wondering if anyone has implemented a widget into experience builder that allows a user to draw on a map widget, select the layers that are within the drawing, and export the features and the drawing.
Any ideas on how this could be done? The draw tool almost does this but does not allow exporting of the drawn features.
Thanks
Tags (1)
TonghuiMing
Hi @mhbangs_EDC
This workflow seems a bit unusual - can you elaborate more on the follow-up expectations of these drawings exported?
If you remove the last part "and the drawing", this is the designed workflow of the Select widget (interactive mode):
a widget...that allows a user to draw on a map widget, select the layers that are within the drawing, and export the features.
If you use a Draw widget (and a Print widget), you can print out the drawn features as PDFs.
