Download data by selection from map?
2321
07-07-2020 06:22 PM
AlbertKochaphum
Hello! Is there any widgets that would allow users to download data by selection on the map in ESRI Experience Builder?
Basically, I'd like the viewer to be able to select data on the map by polygon, rectangle, etc. or by filtering, and then downloading them.
Would be great if that is possible, or should I stick to Web App Builder?
Tags (1)
by Anonymous User
Not applicable
Hey Albert Kochaphum‌, as Shay Lavi‌ has mentioned could be coded with dev edition.
shaylavi
Hi Albert,
At this point, I don't believe such a widget exists, but it can be coded if you use the developer edition.
Shay
by Anonymous User
Not applicable
KimberlyK
I am just finding your question after searching for the same need. Did you find or develop a solution to select data and download the table for them? Thanks.
