Does any of the Experience builder widgets support Image services?
10335
17
01-26-2023 04:11 AM
Sil_
I have a web map with an Image service (containing historical aerial photos) but I can't seem to get much use of it in Experience builder.
I especially wanted to use the Timeline widget, but have been told by my local Esri support that this widget cannot be used with an Image service. I've tried to work around this by using other widgets, but none of them seem to recognize the Image service in my map, specifically the List widget, the Text widget (using Connect to data function), the Table widget, the Filter widget, the Query widget and the Feature info widget. The Image service has a lot of useful data in its attribute table that I want to show in the app.
Am I doing something wrong or do I have to use Web AppBuilder, which seems to handle Image services without problems? I cannot see Image service mentioned in the Experience builder widgets' documentation.
The Image service I am using is password protected, but the url looks like this:
https://services.geodataonline.no/arcgis/rest/services/Geomap_UTM33_EUREF89/GeomapBilder3/ImageServe...
Thanks in advance.
FabianMarthaler_80
We at the Swiss Federal Railways also support this. The Experience Builder should support Esri Imagery Layer as quickly as possible.
by Anonymous User
Not applicable
@FabianMarthaler_80 ESRI provide a roadmap of the product ArcGIS Experience Builder 2024 Roadmap (esri.com). According to this the "raster data source" should be delivered Q2 so assume we should see it by the end of next month.
FabianMarthaler2
Many thanks!
DougBrowning
MVP Esteemed Contributor
Raster support came out today.  I can now see my raster but cannot seem to do anything with it.  No popup comes up except randomly when I am clicking the layer list widget.  Select widget, feature info widget, and query widget does not seem to work on the raster either.
Time widget does not let me add the raster at all.
https://doc.arcgis.com/en/experience-builder/latest/get-started/whats-new.htm
Curious what others are seeing.  thanks
Marshal
When I try to add a multidimensional image layer published from .crf in Timeline widget I get the following warning.  I am still experimenting for work arounds, but I don't have ArcGIS Image Server license which seems to be the clear solution by enabling publishing mosaic datasets.
GeomaticsPublisher
Also adding our support for thee timeline tool supporting raster imagery in ExB. We capure, process and publish significant amounts of LIDAR elevation data using time-aware mosiac datasets which are currently used in a number of web app builder applications across our business. We use image services to publish these mosaic datasets.
With web app being no longer being support by end of 2025 we have a need to rebuild these in ExB however are unable to do this until the time slider supports raster image services and am dissapointed to still see what was an important OTTB tool for many organisations being used in web app still not having been migrated to ExB . A timeline for this would be much appreciated
thanks
Blevins_Mark
i just want to be able to filter my imagery services, as we have overlapping imagery in single services.
Laura
by MVP Regular Contributor
Adding my support. I am trying to filter based on different elevations but the filter widget does not recognize that layer.
