Disabling Sign In Popup
4930
10
12-23-2022 11:00 AM
MarkEastwood
Hi All,
When opening an experience we are getting a popup widow asking us to sign in to ArcGIS Online. Clicking "Okay" then opens up the panel where we can enter in our credentials but we would like to bypass the initial popup.
In Web AppBuilder, we were able to disable the initial sign in panel by editing the ./jimu.js/tokenUtils.js file. On line 17 of the code snippet below, setting the popup parameter to false hides the sign in popup. Is there something similar in the Experience Builder code?
registerOAuthInfo: function(portalUrl, appId){
      var validParams = portalUrl && typeof portalUrl === 'string' &&
       appId && typeof appId === 'string';
      if(!validParams){
        return null;
      var oAuthInfo = esriNS.id.findOAuthInfo(portalUrl);
      if(!oAuthInfo){
        var oauthReturnUrl = window.location.protocol + "//" + window.location.host +
         require.toUrl("jimu") + "/oauth-callback.html";
        //OAuth will lose 'persist' query parameter if set expiration to two weeks exectly.
        oAuthInfo = new OAuthInfo({
          appId: appId,
          expiration: 14 * 24 * 60 - 1,
          portalUrl: portalUrl,
          authNamespace: '/',
          popup: false,
          popupCallbackUrl: oauthReturnUrl
        esriNS.id.registerOAuthInfos([oAuthInfo]);
      oAuthInfo.appId = appId;
      return oAuthInfo;
JeffreyThompson2
MVP Frequent Contributor
https://doc.arcgis.com/en/experience-builder/latest/build-apps/general-settings.htm
There is an option as of the latest ArcGIS Online update. Go to the Gear. Then Privacy and Security.
GIS Developer
City of Arlington, Texas
