Different zoom level in Experience Builder when embedded in TYPO3 vs full view
375
04-27-2026 01:43 AM
AishwaryaRavi
I am using ArcGIS Experience Builder and embedding the app into a TYPO3 website using an iframe.
The issue is that the map shows a different zoom level depending on where it is viewed:
  • In a new browser tab (full screen), the zoom level is correct
  • In TYPO3 (embedded iframe), the map appears more zoomed out
What I have already tried:
  • Set Custom / Fixed extent in the Map widget
  • Tried Use map’s default extent from Map Viewer
  • Saved the map at the desired zoom level in Map Viewer
  • Adjusted iframe height and width (including full width and large height)
  • Removed responsive CSS (padding-bottom trick)
  • Tested different container sizes
However, the embedded version in TYPO3 still shows a smaller zoom level compared to the full view.
Question:
Is there a way to lock the zoom level or scale in ArcGIS Experience Builder so that it appears identical regardless of screen/container size?
Or is this behavior expected due to responsive design, and is there any workaround?
DanielFox1
Hi @AishwaryaRavi
I think you want to use Fixed Scale in the Map Widget
In Experience Builder:
  1. Edit your Map widget.
  2. Under Map Options, look for Initial view or Extent settings.
  3. Choose Lock map navigation or Disable zoom/pan (depending on widget version).
  4. Set the scale you want and save.
This prevents the map from adjusting automatically — but note, if the container is too small, parts of the map may be clipped.
I hope this helps in some way
