Deploying experience to Apache
1703
04-03-2024 05:48 AM
MikeSousa
Hi
I've created an experience in Experience Builder Developer Edition, it works fine in the builder. I've published it and downloaded it. I then installed Apache (on Windows 11). I tested the Apache installation and it works. I copied the experience over to the area of Apache to display webpages. When trying to view it, it give a box
asking to Sign in.  This did not happen in Experience Builder.
When I click OK, it tells me this:
Looks like it's trying to get to the data at Esri
I did fill in config.json with my Esri data:
"attributes": {
"portalUrl": "https://<my company>.maps.arcgis.com",
"isWebTier": false,
"clientId": "#$#$##$$$$",
"title": "feature_info_demo",
"description": "",
"type": "Web Experience",
"thumbnail": null
Any suggestions?
Thanks...
Tags (3)
JeffreyThompson2
MVP Frequent Contributor
When you were installing Experience Builder did you go through all the steps involving creating your credentials? Check that they are properly configured.
https://developers.arcgis.com/experience-builder/guide/install-guide/#create-client-id-using-arcgis-...
GIS Developer
City of Arlington, Texas
MikeSousa
Hi Jeffrey,
I originally went through this inorder to do development with Experience Builder Developer Edition. I'm not sure if I now need to add anything to it, but that may be it, although I don't know what that would be. I was able to run npm ci/start for both the client and server while doing development.
Thanks...
JeffreyThompson2
The credentials wouldn't have anything to do with the npm commands, but if you were able to get past the select your portal/log-in screen, they probably aren't the problem.
Are all of your maps and data layers shared correctly?
GIS Developer
MikeSousa
I think this solved my issue, I needed to add the additional redirect URL:
Now I see my webapp 🙂
Thanks...
