Deleting a custom Experience Builder widget from portal breaks all experiences using it
6611
11
09-21-2022 10:11 AM
TimSexton1
ArcGIS Enterprise 11 now allows for custom widgets to be used directly in ArcGIS Portal's Experience Builder.  In testing this, we discovered that if an Experience Builder app is built using a custom widget, and then later that custom widget is deleted from the Portal's content, the Experience builder app will be rendered useless and need to be deleted and recreated from scratch.
I understand how something that was deleted could no longer be accessed, but why cause then entire app to no longer function rather than having the ability to "remove" or "repair" the individual item (in this case a missing custom widget)?
Instead, we get the full screen error message below:
CONT_0001: Item does not exist or is inaccessible.
lah
haha, I was SICK when I broke my apps, and I think that was my exact same response to the support analyst who helped me. 😅 So glad I could pass it on!
MallorieHoney
We still had this issue on 11.5, but changing the itemID worked! It is worth noting that editing the JSON through ArcGIS Assistant did not fix the issue at all, and we did have to go through the REST endpoint.
