Custom widget re-render content
1171
10-03-2022 09:38 AM
Zoggo
I'm writing a custom widget in Experience Builder 1.5. In a fist step I render html content from a feature layer. After the feature has loaded im loading a related table. After this table has load I'd like to call the render function again and update the content. Unfortunately the content will no be altered. How can I change my content on later point of time? That's seems the question. My actual code looks like this:
import { getFeatureLayerFromDataSource } from 'dist/widgets/arcgis/query/src/runtime/widget-utils';
import { React, IMDataSourceInfo, DataSource, DataSourceManager, DataSourceStatus, FeatureLayerQueryParams, AllWidgetProps, DataSourceComponent, FeatureServiceDataSource } from 'jimu-core';
import { Card, CardHeader, CardBody, CardFooter } from 'jimu-ui';
import { MapViewManager, JimuMapView, JimuMapViewComponent, JimuFeatureLayerView } from "jimu-arcgis";
import * as FeatureLayerView from 'esri/views/layers/FeatureLayerView';
import * as FeatureSet from 'esri/tasks/support/FeatureSet';
interface IState {
  query: FeatureLayerQueryParams;
  jimuMapView: JimuMapView;
  relatedDataLoaded: Boolean;
  el: React.ReactElement;
 * This widget will show features from a configured feature layer
export default class Widget extends React.PureComponent<AllWidgetProps<{}>, IState>{
  state = {
    query: {},
    jimuMapView: null,
    relatedDataLoaded: false,
    el: <div>Text</div>
  query = () => {
    if (!this.isDsConfigured()) {
      return;
    this.setState({
      query: {
        where: '"EpId <> 0"',
        outFields: ['*'],
        pageSize: 10
  isDsConfigured = () => {
    if (this.props.useDataSources &&
      this.props.useDataSources.length > 0)
      return true;
    return false;
  dataRender2() {
    return this.state.el
  dataRender = (ds: DataSource, info: IMDataSourceInfo) => {
    var that = this;
    if (ds && ds.getStatus() === DataSourceStatus.Loaded && this.state.jimuMapView) {
      var view: JimuFeatureLayerView = this.state.jimuMapView.jimuLayerViews["widget_1-dataSource_1-EPIS_Projekt_Ideen_3405"];
      var featureLayer = view.layer;
      const query = {
        outFields: ["*"],
        relationshipId: 1,
        objectIds: [1, 2]
      featureLayer.queryRelatedFeatures(query).then(function (result) {
        this.setState({ relatedDataLoaded: true })
        this.OverviewCard(featureSet.features[0].attributes)
        //     test
        // </div>
        this.state.el = <div>New Text</div>
        this.render()
      }.bind(this)).catch(function (error) {
        console.log("error from queryRelatedFeatures", error);
    if (this.state.jimuMapView) {
    return <>
      <div>Query state: {info.status}</div>
      <div>Count: {ds.count}</div>
      <div className="record-list" style={{ width: '100%', marginTop: '20px', height: 'calc(100% - 80px)', overflow: 'auto' }}>
          ds && ds.getStatus() === DataSourceStatus.Loaded && this.state.jimuMapView ? ds.getRecords().map((r, i) => {
            var fds: FeatureServiceDataSource = ds as FeatureServiceDataSource;
            //var test =  getFeatureLayerFromDataSource(ds,null,this.props.id);
            //return this.OverviewCard(r)
            //return <div key={i}>{r.getData()["EpID"]}</div>
          }) : null
      </div>
  render() {
      return <h3>
        Folgende Datenquellen müssen konfiguriert werden:
        <br />
        - Feature Class Massnahmen
      </h3>;
    let dsm = DataSourceManager.getInstance();
    dsm.createAllDataSources().then(value => {
    if (this.state.relatedDataLoaded) {
    return <div className="widget-use-feature-layer" style={{ width: '100%', height: '100%', maxHeight: '800px', overflow: 'auto' }}>
      <h3>
        Projekte und Projektideen.
      </h3>
      {this.props.hasOwnProperty("useMapWidgetIds") &&
        this.props.useMapWidgetIds &&
        this.props.useMapWidgetIds.length === 1 && (
          <JimuMapViewComponent
            useMapWidgetId={this.props.useMapWidgetIds?.[0]}
            onActiveViewChange={(jmv: JimuMapView) => {
              this.setState({
                jimuMapView: jmv,
      <DataSourceComponent useDataSource={this.props.useDataSources[0]} query={{}} widgetId={this.props.id} queryCount>
          this.dataRender
      </DataSourceComponent>
    </div>;
  OverviewCard(feature) {
    return <Card active>
      <CardHeader>
        <h5>
          {feature["EpID"]}
        </h5>
      </CardHeader>
      <CardBody>
        <h5>
          Card content
        </h5>
        <p>
          Example text for the card content.
        </p>
      </CardBody>
      <CardFooter>
        Card Footer
      </CardFooter>
    </Card>
After I call this.render() on line 74 the function will be executed and return the new value "new text" but the widget show still the old value "test". How can I pass new content to the widget after first rendering?
