Custom Web Tool in Analysis Widget Issue
4331
9
10-31-2023 12:17 PM
taylorrobinfemadhsgovRobin
I have a custom web tool that I am using in the new Analysis Widget. It has an input parameter that is layer. I set up the widget to include a web map with the layer I want user to use as the input, but when I try to use the tool nothing happens when I click the "+ Layer" button. It just says the input is required. If I use a built-in Spatial Analysis Tool, the "+ Layer" button allows me to select the layer from the map.
Wei_Ying
@taylorrobinfemadhsgovRobin
Thanks for your feedback! Could you share more information? What is your parameter type for the layer?
GPFeatureRecordSetLayer or something else?
Correct. In the model that I used to publish the tool, it is the input layer parameter to the Select tool. This GP Service has been working fine in Web AppBuilder, but I wanted to migrate it to Experience Builder.
Wei_Ying
@taylorrobinfemadhsgovRobin It looks like a bug. More questions:
1. Did you see the error inside builder with live view or in launched app with preview?
2. Would you be able to share this gp services with me for a further investigation? (You may give me private message)
PierreloupDucroix
MVP Regular Contributor
I have a similar issue, where my gpserver should allow me to draw on the map, but only allows me to select the point layer that is on my map...
The same is working in my tollbox and in webappbuilder :
WAB :
EXB :
Param :
CEO of MAGIS
Wei_Ying
Hi @PierreloupDucroix ,
Drawing features has not yet been supported in ExB analysis widget. We are working on that. Please stay tuned.
Wei
CarmellaBurdi1
Do you have any indication of when drawing features will be supported? Why would this widget even be pushed out without this capability? The geoprocessing widget capability is a huge need and is currently unusable.
Wei_Ying
The drawing feature in Analysis would be supported in second quarter of 2024.
AValenski
My informed guess is the ExB team needed a "success story" to point to on this front. ExB is and continues to be in beta for an unacceptable length of time. It seems things are marked as 'done' for milestone celebration, but do not align with their actual implementation. Like 75% of their functionality matrix is just an outright lie.
I'm admittedly a cynic, but ExB offers UI advancements at the cost of functionality, stability, and usability, seemingly introducing more problems than it attempts to solve.
Wei_Ying
The drawing feature capability is already available in ArcGIS Online since its February release.
Thanks for your feedbacks!
