Custom PRINT TEMPLATE
6419
15
02-17-2024 12:20 PM
HariomPandya
can ANYONE help me in the custom print experience builder widget  . print preview is not showing for my custom print select , if i change it to map only or any other like a-4 portrait  it is working .
i want to have print preview for my custom print service custom template  . please help me in this .
HariomPandya
Ok let me try this , and will let you know . Thank you so much
HariomPandya
Hi @ShengdiZhang  , i  am directly publishing both task from pro to enterprise . is there something i have to check from server folder
HariomPandya
The server is of client and thats why you will not get access .
Will you please guide me somethings else where i can look upon
HariomPandya
Hi @ShengdiZhang
Hi can you help me in custom print layout. What Format should i give in Author . currently in my print service hasAuthorText is coming false . i wants this to be true .i am working in arcgis pro .
ShengdiZhang
I was unable to add the author to the layout myself. However, you can add a custom text element as a workaround.
Shengdi
DOTPGIS
Did you find a solution for this? I am having a similar issue. 😩
