Custom No Data message for ExB chart Widget not working
4188
16
05-07-2025 01:19 AM
ElieRizk
We have been waiting for ESRI to solve this issue for a long time. Still, unfortunately, in EXB developer edition 1.17, ESRI mentioned that this issue has been solved: "You can enter a message to display when no data is selected or the chart is otherwise not displaying data." We tried to fill it out as requested, but unfortunately, this is not working.
Kindly advise, are there any additional steps to take after filling in the custom message?
Wei_Ying
Hi @ElieRizk this issue has been fixed on AGOL June release.
ElieRizk
Thank you. I checked it, and it partially solves the issue.
The message placement is not visually prominent for users; consider repositioning or highlighting it to improve visibility. It would be more effective if displayed near or directly above the grey bar charts to draw attention to the context of the missing data
RSchaffner
The customized "no data" message is not working in my project. In the screenshot below, there is no data in the filter for the E. coli chart, but the customized "No Data Available" message does not appear anywhere. Any suggestions?No_Data.png
ElieRizk
@RSchaffner  As mentioned by @Wei_Ying , the update was implemented in the AGOL EXB June release (it is shown as per my screenshot), not in the Developer Edition. Unless I missed something, this means the availability depends on which version you are currently using.
Wei_Ying
Same fix is also available since Dev edition 1.18
Danfranco
Can you inform when this will be available within the Experience Builder on ArcGIS Enterprise?
I am using Enterprise 11.5 and I see the 'Customize no data message' but it does nothing.
Can you inform when this bug will be fixed, and will it be fixed via a patch or at v12.0?
Wei_Ying
Hi @Danfranco for Enterprise that's 12.0.
