creating select feature functionality in a custom widget using Sketchviewmodel widget
831
03-04-2024 07:35 PM
digisathish3032
I am trying to create a select feature functionality in a custom widget using SketchViewModel library. This functionality already available in the Map widget. However, as per the requirement, we need to build the same using custom widget. I am using the SketchViewModel library from esri. When we play the builer, we are gettting console error which says 'skecthviewmodel.create is not a function'. Experience Builder version is 1.13, Node version 16 & JS 4.28. pls suggest a solution to resolve this issue.
