Creating Map Failed Error
8141
7
01-16-2024 11:47 AM
JoshBillings
Hello,
I have a web application created using Experience Builder. All of a sudden, a user is experiencing a "Creating Map Failed" message when try to access the web application. The user has been using this application for the past couple months with no issue. We have tried clearing the browsing data/cache with no luck. A screenshot of the browser error can be found below.
I (the creator of the experience builder) can access this web application with no issues and it doesn't seem to affect any other users.
Josh
JeffreyThompson2
MVP Frequent Contributor
Most likely the issue has to do with the sharing settings on the webmap. Make sure that the webmap is shared publicly, to the organization, or with the correct groups, whatever is appropriate for your application and that the user has the correct credentials to view it.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
GIS Developer
JoshBillings
Wow, I feel silly, that's exactly what it was. Thanks @JeffreyThompson2 !
JeffreyThompson2
I've seen the error because I've done it before, more than once.
GIS Developer
AlexErnst_IDPR
Having same issue with a random user, in Chrome only (but functions okay in Edge on same PC). App is public.
What would be the approach to diagnosing this on a single PC when the issue is with Chrome only?
App https://experience.arcgis.com/experience/97a42a2a73c944ba918042faf518c689
App frame renders but the map (widget) will not render, and none of the several various widget buttons and Search dialog will render.
samc-gis
Any update on this? Experiencing the same issue where I have an experience shared publicly and the customers are getting the "creating map failed" error but the app frame renders. I've tested opening the experience in multiple different environments with various browsers and they all work for me, but it won't work for the customers no matter what browser they use. I've followed all Esri documentation for the issue and still no change.
AliciaMcMurchie1
Are the browser versions up-to-date?
AliciaMcMurchie1
Updating browser version resolved this issue for a few users at my agency.
