I want users to be able to add new records in a (non-spatial) table within experience builder. I created a new hosted feature layer table, but it seems the table does not show up as an option to add to the Edit widget in ExB.
Although I can add my table to the Table widget in ExB, there is no option to 'Create new record' like you can in map viewer attribute table.
Am I missing something obvious?
Update: by using a second Edit widget and instead of selecting the option 'Interact with a Map Widget', I use the 'Attributes Only' option I can select the table layer as an option for editing. This allows users to 'Add New' in that widget. That gets me what I need to for now. Still would be nice to have 'Add Record' in the table widget.
I see an idea has been out there for this since 2021. That's depressing that this basic function still isn't in the ExB widgets.
