Connect Multiple Data Sources to the Embed Widget
1967
04-01-2021 08:06 AM
MatthewCriel
Hello everyone:
I want to use the embed widget to connect map data to our document management system but there is a limitation that I cant figure out.
The embed widget only allows me to connect with one map feature / URL populated field at a time . We have multiple features that have URL populated fields and I would like to connect the embed widget to all of them. Also we have layer with multiple URL fields.
All of my URLs point to the same website just the Unique ID changes.
Here is the example: https://123.org/lf/Browse.aspx?db=xx#?id=80617
Can I build a expression to grab the ID fields in multiple layers and populate this URL properly?
is there another workaround, such as using the map popups or list widget to display the URL links and open them with the embed widget?
Thanks
JonathanMcDougall
This is an April Fool's ctrl-c ctrl-v error, then.....well done. Anyone dropping in on this post, don't click the link, its content is clear.
MatthewCriel
Forgot the NSFW tag lol
