communicating between custom widget and OOTB table widget
1020
04-23-2025 12:44 PM
wanderer1
Hi
I am building a custom widget that makes a selection on the map. To have the corresponding rows highlighted in the OOTB table widget how do I go about doing this?
Can I use
MessageManager.getInstance().publishMessage(
               new DataRecordsSelectionChangeMessage(props.widgetid, ds.records, [props.dataSource.id])
or do I need to extend the current table widget to listen to a new message I send from my custom widget?
Thanks
Allen_Zhang
Hi @wanderer1 ,you can try select the record by dataSource.selectRecordById(recordId, record) or dataSource.selectRecordsByIds(recordIdArray, recordArray).
The table will hightlight these records automatically.
Allen_Zhang
wanderer1
Hi @Allen_Zhang
That is what I have tried doing and it does select on the map, but not in the table.
dataSource.query({ objectIds: [ "1","2"], returnGeometry : true }).then((qr) => {
          dataSource.selectRecordsByIds?.(
            qr.records.map((item) => item.getId())
wanderer1
Was missing the second argument. Thank you!
