Clear Data Filters Action Makes Filters Disappear
398
5
07-10-2026 10:58 AM
JeffreyThompson2
MVP Frequent Contributor
I've tried out the new Clear Data Filters Action and it has some undesirable behavior. When I click my Button to clear the filter, all the Filter Widgets in active use just vanish from the Page. See video.
(view in My Videos)
The data is unfiltered (so I guess it technically works), but only if I go into the Settings for the Action and specifically target the Datasource. The All Data option does not work on an Output Datasource.
If I was a user hitting a Clear Filters Button, I would not expect to never be able to make a new Filter. This cannot be the intended design. If it is, this needs to be redesigned, because this Action has extremely limited utility in its current form.
GIS Developer
City of Arlington, Texas
SumingSun
@Jianxia  It's reproducible with a predefined clause & clear action.
@JeffreyThompson2  Thank you for reporting this issue. We will fix it in a post-UC patch.
Jianxia
@JeffreyThompson2, Thanks for trying this new feature. I am not able to reproduce it. Could you please share a reproducible sample?
JeffreyThompson2
https://experience.arcgis.com/experience/66e2013c8455408e899968be76d1129f
I've published this application with the Button in the Filter Accordion in the lower-left.
GIS Developer
SumingSun
Suming
@JeffreyThompson2 The bug was fixed with the last patch. Please help verify it ~
JeffreyThompson2
@Suming The filters are not disappearing in my demo app.
GIS Developer
