Charts widgets do not reset selection (previous selection) after main filter reset
991
07-01-2025 01:42 AM
ElieRizk
I am building a chart in experience builder but I am facing the following behavior between the main filter and chart widget:
  • The main filter controls the data feeding both the map and the chart widget.
  • When a bar is selected on the chart, the selection is correctly reflected on the map.
  • However, after resetting the main filter, the chart visually indicates that the bar selection has been cleared, while the map still retains the previous selection/filter.
    This suggests that a hidden query remains active. Even using the chart’s “Clear Selection” tool has no effect on the map.
  • To fully clear the chart selection and its impact on the map, the user is forced to select another bar and manually clear it again.
Thank you.
Ke_Xu
by Esri Regular Contributor
Hi @ElieRizk,
Could you provide a sample app for us to troubleshoot? I couldn't reproduce this issue with this app https://experience.arcgis.com/experience/1400c79aa7a64c0aa478c32c086c9405.
Ke
Wei_Ying
If the filter does not get reset, it sounds like a bug. Could you submit a ticket to support to provide us more details if you are still seeing this problem with latest version. Thank you!
