Chart Widget not showing domain descriptions
499
01-16-2026 02:53 PM
LindseyStone
Has anyone had any look with Utility networks with subtypes domains showing correctly in the Chart Widget of Experience Builder?
When I have a Category type of Group By and Category Field that is a domain within a subtype, the X axis shows the domain code instead of the description.  However if I set the same field as the Split by field it correctly shows the domain description.  On the below screenshots you can see that Material shows the description when used in the Split By Field, but when set as the Category field it shows the domain code.
When utilizing the Lifecycle Status and Spatial Source as the Category fields which are also domain fields, correctly show the domain description.  The difference those two domains are set on all Subtypes.
I'm utilizing Experience Builder within my Portal 11.5.
