Change View when Selection is made on Map Widget
721
10-17-2023 10:21 AM
RobertAnderson3
MVP Regular Contributor
I've set up a list widget and a map widget for my ExB, the list is in a view pane, and then the second view contains the Feature Info widget (this template came from the Place Explorer template Esri had available earlier in the year, which doesn't seem to be there now?).
When you select an item in the List, it pops up the second view and shows the Feature Info widget, however when I select an item on the map it does not bring the Feature Info view forward, it does select the item on the List though, and when I select an item on the map while the Feature Info view is open, it changes to the selected item.
Is there a way to make the map selection change the view and move my feature info widget in front of the list?
For reference, I'm trying to make something similar to the Shortlist Story Map template that's been in extended support for a WHILE now.
