change size of pane in Map Layers widget
5400
11
09-30-2024 09:07 AM
JasonFitzsimmons
The Map Layer widget, when open, has a long pane that extends to the bottom of the window.
See the attached screenshot.
I have an read-only Experience Builder internal app deployed on ArcGIS Online.  The map uses both user managed locally published map services and hosted feature services.
There is a lot of unused white space and it blocks other items from view.
There is no styling capability available for this widget apparently. Is there a workaround, or any plans to add styling to this widget?
It would be nice if it were dynamic, so it was only as big as needed for the given number of layers.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/map-layers-widget.htm
JasonFitzsimmons
ps to get around the issue I raised above, I just put the layer widget into its own controller and adjusted the alignment and spacing so all the widgets are uniform. simple enough.
Woosh_AP
I have a similar question: is there any way to get rid of the large spaces around the text in the Map Layers Widget in Experience Builder? Resizing the frame just forces the text to wrap to the next line. This is really annoying as it requires the widgets to be a lot bigger than necessary on smaller screen. It would also be great if the text size could be reduced and if the background colour could be changed.
