I found this post which was helpful in removing layers from the initial view. I also have 3 views setup filtering the data for a Feature Layer.
Is there a way to set the initial view for each page in a Multi-Page Experience without adding separate web-maps for each page EG on Page 1 I would like the initial map to be New Development View, on Page 2 Redevelopment View and on Page 3 Land View?
This sounds pretty neat and I can imagine wanting to do something similar myself.
Hi @NancyDees , any luck with the issue you posted earlier in the year?
I'm after having a page with two different views of the same webmap. The idea is having a map that opens up by default with a combination of layers on to go along with an intro text. Then, having a section of text linked to a different view of the same map. If a user clicks on that section, the same map with different combination of layers on is to come up.
I can see the option of using a webmap with different extents. However, I cannot see an option for configuring a view of a webmap with different combination of layers turned on for different views.
I am looking to do something similar. I have a web map and would like layers to be turned on and off based on which page you are on within my web app. I haven't found a solution for this yet.
