Cannot run tool with featureSet parameter
1359
08-03-2025 10:18 PM
ModyBuchbinder
I have my own gp service that gets a point as parameter.
After I published it I can run it from Pro, I can add it and run t from a WebMap and I can build a Web AppBuilder (old) that running it with no problem.
When I try to build experience builder and run it (Enterprise 11.5) I get the error you can see in the attachment.
Tring to run it with EB developer works fine!!
Is it a bug??
Ke_Xu
by Esri Regular Contributor
Hi @ModyBuchbinder ,
Could you share the app or detailed steps for us to troubleshoot?
Ke
ModyBuchbinder
Hi @Ke_Xu
It is very simple.
Create a Python script that get one parameter
The script should not do anything else, the problem is before the script is running.
You can open a cursor on the FeatureSet and print the coordinates (just for check).
In a atbx I created a new script tool, the first parameter is a feature set that get point only (filter in the parameter screen) and pointing to my script.
Run and publish.
Try to use in experience builder
As I said it works in REST, Pro, WebMap, old WAB and EB developer
ModyBuchbinder
Hi
I am not sure I understand. Is this in the EB setting?
There is nothing wrong with the gp service, it works from all the other applications.
