Can you use Text Widget to display statistics of Query Widget result?
1865
01-19-2023 07:27 AM
RoseZhou2
Hello,
I have a Filter widget, a map and a Text Widget on an Experience Builder page. I can use a Filter widget to filter the map data and display the statics of the filter result on a Text Widget using dynamic text.
But, on another Experience Builder page, I have a Query widget, a map and a Text Widget.. I want to use the Query Widget (Attribute Query and Spatial Query) to select some data, and display the statictics (for example, Count or Sum) on a Text Widget using dynamic Text. I can't figure out how to make this work. Is it possible to do it?
If anyone has a suggestion, please let me know.
Thanks!
Rose
WC48
You can link the table widget to the query result and then link the text widget to the table for a sum result. It's a bit clunky and minimal options for style of the text window. It's a work-around solution for now until they can hopefully add the statistics option back as a default for both the filter and query tools.
Have a great day!
Will
WC48
Have a great day!
Will
RoseZhou2
@WC48 , thank you so much for your quick response. That workaround did the trick!
The only thing is when nothing is selected, the table displays nothing, which does not look good. I may have to hide it.
Regards
Rose
WC48
Awesome! So glad you got it. Agreed. We added some text in the window, and dressed up the box, so that at least it has a visual indicator that something is going to happen there 🙂
