Can you control output layer order from output of analysis widget?
835
07-24-2025 06:55 AM
mhaley_stone_env
I have a GP tool that is loaded up in the Analysis Widget in XB. The output layers from the tool are added directly to the map on the fly each time the tool is run. Is there a way to control the layer order in XB? I am finding that every time the tool is run, the layer order in the web map changes! I have the order specified in the GP script, and it is consistently reproducible when the GP tool is run in Pro but as soon as it gets to XB, *poof* inconsistent layer order every run of the tool. Can someone on the experience builder dev team explain this bug?
Ke_Xu
by Esri Regular Contributor
Hi @mhaley_stone_env
Thank you for pointing this out. ExB does not currently support this feature. We will look into this feature further to see if it can be enhanced.
Ke
mhaley_stone_env
Ke_Xu
Ke
mhaley_stone_env
Thanks @Ke_Xu! This is a pretty critical function that was part of Web App Builder Geoprocessing widget and  would be something that would be really helpful to have as a feature of the Analysis widget.
